30-05-2020 08:19 AM in
TVGood morning,
We have had Disney+ installed on the TV for about six weeks now and has been working fine. Unfortunately when trying to access it today I get an error code 1016-app_config_failure
I have switched off the power to the TV and chosen reinstall from the apps menu, but the error still occurs. There is no option to delete from the menu as it says that "The basis set of apps on your device cannot be deleted ".
I can access Disney+ from the firestick in a different room, so there is no problem with there.
Please help as the children are used to watching films on the tv.
Thank you.
Solved! Go to Solution.
03-06-2020 11:56 AM in
TV30-05-2020 09:08 AM in
TVWe are also having the same problem and it seems a lot of people are hopefully they will fix it soon!
30-05-2020 09:20 AM in
TVThis has happened to me also this morning. Worked fine last night, looking at the US forum they are also experiencing the same thing. Seems it's a software update from samsung that's not compatible with the Disney app. People have had replies from Disney that they don't know when they will be able to fix. Work around is to install on firestick. Pretty annoying and bad service to brick the biggest App going
30-05-2020 09:24 AM in
TVThank you for your reply. Hopefully it will get sorted soon, as I can't see my patience lasting if I have to swap the firestick out between TVs 😀
30-05-2020 09:27 AM in
TVSame issue here. Complete reset of the Smart Hub didn't solve the problem. Looks like it's a universal problem with a lot of Samsung TVs since the 29th May.
30-05-2020 10:21 AM in
TVSame issue here. Was working fine last night and now this morning it's stopped working. Very frustrating.
30-05-2020 11:21 AM in
TVExactly the same problem here. Samsung web chat has been unsuccessful with their recommendations: power cycle, reset hub, DNS to 8.8.8.8
They have escalated and given me a case number. Disney have suggested uninstalled and reinstalling app, but this doesn't seem possible on TV.
30-05-2020 11:56 AM in
TVJust a quick fix for error 1016 for those of you that have Sky Q, you can use Disney + from the App section or use Smart veiw on your Mobile phone to cast Disney + to your TV until Samsung & Disney pull their fingers out of their a***s.
30-05-2020 02:33 PM in
TVSame here. Looks like Disney+ is broken for all Samsung smart TVs after this update.
