Difference between RU7020 and RU7100
(Topic created on: 06-11-2019 02:19 PM)
Radgebob
Hi,
Can anyone tell the differnce between these two tv's as they look identical on the site. I'm interested in buying one of them and there is a 50 pound price difference between them but i've searched and can't see a difference.
Thanks
6 REPLIES 6
CarlH
Radgebob
55 inch. Specs look identical cannot see any difference
HazHard
Hi there, has anyone got an answer to this. I'm looking at the 75" and when I compare the specs side by side I can't see a difference except price??
Mauriziow
Did you get an answer for this? If I'm on the RU7100 website, I get descriptions for the 7020. The only difference I see are the legs. I'm trying to get the 50".
JAMES4578
Samsung Members Star ★★
@Mauriziow  Can not see any difference, other than the Dimensions.     Display, specifications the same, Both suppprt HDR10+ and given PQI of 1400.      Checking the 50 inch versions:
RU7020:
  • Set Size with Stand (WxHxD) 1238.6 x 758.2 x 242.1 mm
  • Weight with Stand 13.5 KG
 RU 7100:
  • Set Size with Stand (WxHxD) 1124.8 x 728.8 x 261.3 mm
  •   Weight with Stand 13.9 KG
Radgebob
Thanks for that 😀 The only other one I can think of is the wifi. I got the RU7020 and it only has 2.4ghz wifi whereas I think the RU7100 has both
