Device connected
(Topic created on: 07-03-2023 01:56 AM)
Bumbi1
I keep getting a pop up. Device is Connected. Device Name: PK.  Anyone else getting this pop up. It happens like every 10 minutes.
8 REPLIES 8
ChrisM
SuperStar
Hi @Bumbi1
Could we take the full model code and current software version of your TV please? Go to Home > Settings > Support > About This TV.
Bumbi1
MN : QN75QN90BAFXZA
FW : T-PTMAKUC-1430.1
PaulM1
Thanks for that, @Bumbi1. I have edited your post to remove your serial number, as this is information that is personal to you. Please can you check to see whether there is a software update for your TV and, if there is, whether downloading and installing this resolves the pop-up message?
https://www.samsung.com/uk/support/tv-audio-video/how-to-install-software-and-app-updates-automatica...
If there is no update available, please could you upload a photo showing the message that you have been seeing on your TV? This will give us a clearer idea of how this presents itself.
Bumbi1
Thanks.  Good looking out. No available updates.  I'll try to take a picture of it when it happens.  It's super random.
Bumbi1
PaulM1
Thanks, @Bumbi1. That's very helpful. Not to sound too obvious, but I believe that this is just referring to a device that is connected to your TV. It's possible, of course, that "PK" is a wireless or wired connection.
If you haven't already done so, I recommend having a look at the devices that are connected to your TV and remove any that you no longer require:
Settings > General > External Device Manager > Device Connection Manager > Device List > identify and remove any unwanted devices.
Bumbi1
Thanks Paul. I checked my connected devices and removed the only wireless connection, my phone. For wired devices, I have the cable box and my Xbox. Is it expected when we have these "normal" identified wired devices connected that this message show up every 2 to 3 hours every day? I replaced the HDMI cables to all new ones and it's still occuring.
Hjm68
I get the same thing when I turn on my tv. The device is connected:  Snoo
samsung isn’t telling us something
I even renamed my network and unplugged from my router and rebooted my tv and it still popped up.
It’s Samsung - they are spying on us via the tv.
