Curve tv help
(Topic created on: 29-07-2023 10:57 AM)
Verve-eclipse
I hope someone can help me. My curve tv was on standby mode (off but still had power) when all of a sudden the screen started flashing , I couldn’t turn it on , I unplugged the tv for a couple minutes then plugged back in, the flashing got worse and there was smoke and a bad plastic burning smell after that the tv would not work. Would anyone know what caused this? Would it just be the tv or should I be worried I have an electrical issue with the plug? Many thanks
1 REPLY 1
JAMES4578
Samsung Members Star ★★
Hi @Verve-eclipse   Sorry to hear this , Samsung do take such issues seriously. With smoke and burning this is a  Health and Safety issue, do not attempt to use the Tv and ensure that it is unplugged.
I would advise that if you are resident in Uk/Ireland  you are best  send a Private Message to Sam_UK and  this will be investigated.   One of the Moderators will respond. If you are unsure how to do this follow this guide  https://eu.community.samsung.com/t5/samsung-lounge/how-to-send-a-private-message-on-the-samsung-comm...
One Ui 5.1,Android 13 .
