05-04-2023 08:57 PM - last edited 05-04-2023 08:58 PM
my tv is the model ue55tu7020kxxu
I have bought a genuine samsung tv remote but it will not connect.
Are there any universal remotes (with voice control) which will connect to the ue55tu7020kxxu tv?
05-04-2023 10:38 PM - last edited 05-04-2023 10:38 PM
Hi @g25rose Whilst often works automatically did you press and hold the Return button and Play/Pause buttons simultaneously for at least 3 seconds (pointing at the sensor) https://www.samsung.com//support/tv-audio-video/tv-pair-your-smart-remote/
Anyway could check these sites here:
https://www.samsungspares.co.uk/sound-vision/tv
However on a quick search on a few sites not finding Smart/Voice controlled remotes.
There is this one on Amazon though not totally sure of compatibility (says supports various models). https://www.amazon.co.uk/Samsung-BN59-01330B-Genuine-Remote-Control
One Ui 5.1,Android 13 .
