Support
Open search
Can’t pair smart remote to TV
Highlighted
I asked a question the other day regarding my TV not connecting to my soundbar, now I can't connect to my smart remote so I'm wondering if I have an issue with the TV's Bluetooth?
from my understanding the remote initially uses the IR sender to connect then uses Bluetooth to connect to all devices?
As previously mentioned I can't connect my Bluetooth soundbar, I'm having to use an optical cable, and now the remote, so is there a way to reset the TV Bluetooth or something?
the TV is a QE55Q70RATXXU and I'm using the black smart remote, the store originally gave me the silver metal one and that wouldn't pair so I presumed it was due to the remote, now I can't connect to this one either
thanks
2 REPLIES 2
Highlighted
Have you tried to re-pair the remote by pressing the back and play/pause buttons together ?
Highlighted
Yeah that's what keeps failing, only the on/off button works with the remote, so I try pairing and it fails
Top Liked Authors
