Bluetooth For My Samsung TV
(Topic created on: 26-04-2021 11:56 AM)
Iktisman
I have a UE40 MU6120 TV and I want to use Bluetooth headphones with it.  As it doesn't have Bluetooth I need to find a way to set it up with a Bluetooth transmitter.  As it does not have a 3.5mm output or RCA outputs this leaves me with just the Optical out which is already in use for my soundbar.  How can I fit a transmitter? Is it possible to do this via an HDMI port, if not then how can it be done?
My technical knowledge is very limited so please recognise this if you reply.   Assume that you're dealing with an *****, which you probably are!
1 REPLY 1
jeffybaconarms
Navigator
Don't know much about BT transmitters but is there not one with an optical pass through?
