Support
Open search
bluetooth connection from tv to earphones
Highlighted
New Member
Hello, i have just purchased a samsung UHD TV, Model NO UE40MU6100KXXU , i am hard of hearing and wondered if i can connect a pair of bluetooth headphones to the tv and if so please advise how i do this ?
if i do manage to connect sucessfully do you know if  there will be a delay from the tv to the speakers ?
also i want to buy  home cinema system to connect to the tv also , is it best to get a samsung system or does it not really matter ? if a samsung system is the best option then what would be the best system to get for this particular TV ?
many thanks in advance
stigworth1970
1 REPLY 1
Highlighted
Hi there @stigworth1970. :smileyhappy:
Can confirm that the UE40MU6100KXXU supports Bluetooth headphones. Pulled some relevant info from the TV's E-Manual for you:
For Home Cinema systems, I'd recommend Samsung ones here for best compatibility. The higher the letter after that 'HT-' in the model code the more recent it'll be. Others in the Community may have other suggestions for you though.
 Say "Hello!" to the Community in The Introduce Yourself Thread.
Top Liked Authors
