Go to solution Solved
Bixby not working after fw update to 2010 - smart monitor m7
(Topic created on: 27-04-2022 11:28 AM)
koniwood
TV
The subject pretty much sums it all. After fw update to 2010 (26/4/22) on smart monitor m7 bixby no longer loads on prompt from remote. It constantly gives message: "just a moment, it's loading"
koniwood
TV
A quick update - bixby started to work on its own. Seems also quicker in recognizing commands.
3 REPLIES 3
SilverBell
TV
this just happened to me too. I couldnt voice search on youtube either.
After resetting everything , the mic worked again but I had to go back and change all the settings again and log back into my accounts. a massive time waste
koniwood
TV
Actually, the mic seems to be working okay - voice search on youtube works just fine. It's just the bixby thing.
koniwood
TV
