26-11-2017 04:12 PM
I purchased a UE40KU6000 in April 2017. BBC iplayer worked like a joy. Over the past 6 weeks, every time I choose to stream a programme the iplayer picture flickers continuously rendering the programme unwatchable. The sound is fine.
I have tried turning off all other WIFI devices, signing out and uninstalling the app. I even reset the tv but I still have this problem. All other apps work fine.
Does anyone have any ideas? I use iplayer the most
27-11-2017 08:47 PM
Hi @top1.
What software version do you have on the TV? Go to Home > Settings > Support > Contact Samsung.
27-11-2017 08:50 PM
I have the latest firmware 1208.2 down loaded last week
28-11-2017 06:05 PM
Hi Chris
The software version reads as T-JZL6DEUS-1201.6
Sub-micon version T-JZMDEUS-1007
30-11-2017 07:10 PM
I am having the same issue on my KS8000 have you had any luck resolving?
30-11-2017 07:38 PM
65KS9500
I been having this issue since August. They have replaced the one connect and main board but still will not record. I was promised a call back from them last Sunday, still waiting. Not very good just keep getting that they are busy when I ask where the call back is on facebook messaging. It is frustrating, I spent a lot of money on what I thought was the best TV. Still good TV but if you have a problem like a few others on these forums then they are very poor.
I bought a Hewlett Packard printer 7 months ago off Ebay. It developed a fault in it would not scan. I contacted HP support, and after afew checks they agreed there was a fault and after 3 days I am receipt of a new replacement, brill service, just wish Samsung were as good. All I had to supply them with was the serial number and theychecked warrenty and sorted.
02-12-2017 08:32 PM
No. I'm really hacked off. It worked amazingly until about 2 months ago. Interestingly, I've changed the iPlayer setting to standard definition - the programmes play without flickering but the screen proportion is wrong, almost too zoomed in.
