Go to solution Solved
BBC iplayer freezes after 30min on TV
(Topic created on: 30-03-2020 09:57 AM)
Graham_S
Hi
I have a UE40JU6400. When viewing content on BBC iplayer the iplayer will run for about 30 minutes before freezing and then saying somehting is wrong and suggesting I change a setting on the TV, which has been done. I have to turn the TV off and restart it then back to iplayer. iPlayer then offers to resume and accepting this it will run for a furthe 1/2 hour and then freeze again.
It have a Manhattan freeview box which also has BBC iplayer and I have no problems watching the same content on the box. it doesn't freeze.
Both the TV and the box are directly connected (wired) to the same internet source
What would be causing the TV to freeze?
CarlH
Thanks @Graham_S. Have you tried a Smart Hub reset? This can be found in Settings? Menu > Support > Self Diagnosis > Smart Hub Reset. This wil sign you out of other apps too.
19 REPLIES 19
CarlH
Hi @Graham_S. Can you confirm the software version? This can be found under Support > Software Update.
Graham_S
The version is 1550 and auto update is on
CarlH
Graham_S
No I had'nt but have now done so. I'll try it again later. Thanks
Graham_S
Many thanks. It's been running an hour now so all semms well
Graham_S
Ooops, spoke too soon. It has just lasted 15 mins before freezing. Time to switch to the Manhattan box as my iplayer source
CarlH
Graham_S
We only use Netflix and iplayer. Netflix is fine.
CarlH
I've just messaged our Product Specialists and will get back to you as soon as I can.
