BBC iPlayer, 4OD and ITV Hub won’t open on UE43TU7000KXXU TV
(Topic created on: 20-09-2020 08:12 PM)
Asedg440
Hello,
As mentioned in the topic title, for a few hours now I simply cannot open any of the catch up TV services on my smart TV - the icons are there, and suggest shows still pop up when I select them, but  pressing the button to open them does nothing at all. If I hold it then I get the option to remove or move the icon, so the button is still working. Netflix, Apple TV and Amazon Prime all still work as normal. I have tried disconnecting and reconnecting the internet, and resetting the network to factory settings - still no luck. Any ideas?
2 REPLIES 2
ARahman
Try factory resetting, most of the times it works after factory reset.
Gordon10
Already tried this solution
