Audio connect
(Topic created on: 28-09-2022 06:10 PM)
Magar68
Advice please. I have a:
-Samsung qe55Q80A TV
-#Sky Q box
-#Denon #CEOL RCD-N11DAB hif
How can I connect them so that TV sound is played via the Hi-Fi speakers?
thank you in advance…
2 Solutions
ScrappyCocos
Navigator
Hi!
Based on your setup, your Denon Hi-Fi system is capable to connect to your TV via optical cable only.
Connect your optical cable to your devices and select the optical connection on both of them. It should work.
" If at first you don't succeed; call it version 1.0 "
AndrewL
@Magar68: Further to the above, connect your Hi-Fi via optical cable, then head to Home > Settings > Sound > Sound Output, and select 'Optical' from here.
4 REPLIES 4
ScrappyCocos
Navigator
Hi!
AndrewL
Magar68
Thank you both
Rachel Gomez
Follow the steps below.
Turn on the speaker you want to connect to, then press and hold the pairing button.
Power on the Samsung Smart TV.
On the remote control, press the Home button, then select Settings.
Navigate to Sound > Sound Output and select Bluetooth Speaker List.
This may help you,
Rachel Gomez
