Attaching SSD to Samsung TV
(Topic created on: 22-05-2020 06:16 PM)
Ben1l1l
Hi, I have a Samsung QE49Q6FNA. I want to attach an SSD to be able to record TV. I've connected my Samsung T5 SSD but the tv appears to see 2 drives rather than just the single SSD. One of the drives shows up as only about 200mb, the second one shows up as the correct 300gb, but It won't let me record to it. Why is the SSD showing up as two sepperate drives (the SSD has NOT been partitioned) and how do I set the larger drive to be the one the TV records to?
Thanks!!
5 REPLIES 5
TessM
Mastermind
Hey @Ben1l1l ,
are you able to tell us how do you have this connected to the TV and if the SSD is blank? If not, can you try to format this and see if this is still happening?
Ben1l1l
@TessM
Hi, the SSD is connected to the TV via a USB port.
The SSD was formated on a mac to Ex FAT same result. I then tried formatting the SSD again to Mac OS journaled. Again same result.
TessM
Mastermind
Have you tried to plug this to a different port and is the same showing when you connect this to your computer?
RouDeR
Pathfinder
Format it to NTFS
tarumain
Hi Did this actually worked?
Note: i have the PW turned on.
