02-02-2021 05:03 PM - last edited 02-02-2021 05:25 PM ) in
TVI noticed that when I play a show or movie with the AppleTV app on my Samsung SmarTV, although subtltes are properly selected, they don't work. Tried several options, even with other languages. Nothing.
When I use my smartphone app and cast the show to my TV, the subtitles work normally.
I looked for solutions on the web and they suggest "Settings > General > Acessibility > Subtitles > turn on". There is no such "turn on" on the appleTV app on the TV, only style choices.
Any help would be appreciated.
02-02-2021 07:05 PM in
TVUN43RU7100G
04-02-2021 11:57 AM - last edited 04-02-2021 12:01 PM ) in
TV@AndrewL so? Any ideas? I'm still only abte to get subtitiles via smartphone.
Last night the subtitles suddenly worked on the TV app, but in another language. When I tried to change it, nothing worked anymore, not even the language it was working. Pretty buggy.
04-02-2021 06:32 PM in
TV@cdechery: On the TV itself, can you try heading to Settings > General > Accessibility > Subtitle Settings > Subtitle, and disable this feature. Now, in the Apple TV app, go to Settings > Accessibility > Subtitles and Captioning, and turn Closed Captions and SDH on.
If the issue persists, can you confirm where you purchased the TV, and where you're currently based?
04-02-2021 06:50 PM - last edited 04-02-2021 07:15 PM ) in
TVHi Andrew, like I said in my original post, there is no such option to turn ON or OFF the subtitles in the AppleTV TV App (nor is there in the smartphone app either).
Here is a screenshot of what General > Accessibility > Subtitle Options look like here (only styles choice, no ON/OFF).
I'm in Brazil, got the TV here, but the Brazil forum is very weak, so I might try some help here.
