21-07-2019 05:42 AM
I have a Samsung Q9 65 with the latest firmware (version 1260) and use Anynet+/HDMI-CEC to connect a SONOS sound system which works well.
However, when I select the AirPods as the sound source with Anynet+/HDMI-CEC enabled, the AirPods connect for approximately two seconds then the sound reverts to the SONOS sound system.
If I disable Anynet+/HDMI-CEC, then the AirPods stay connected and work well.
Is there a way I can use the AirPods without having to disable the Anynet+/HDMI-CEC feature each time ?
23-04-2020 10:05 PM
24-04-2020 12:58 AM
@Lejlollipop wrote:
Hi,
Did you find any solution to this problem that you can share? I just met it too.
Sorry I did not find a solution. The only way it works is if you disable Anynet and use the built in TV speakers but then you lose your surround sound !
