08-05-2020 03:38 AM
I recently got a 65Q90T. When I use my iPhone or MacBook to AirPlay to the TV, it goes into multi view mode. I can then click on the screen showing the AirPlay'd screen but then it has a banner on the bottom which says:
"Multi View: To return to the previous screen, press and hold (back button) on your remote".
The banner never goes away. I'm running the latest software as well... Any solutions?
11-09-2020 06:22 PM
Having wasted 2 hours on the phone to various so called Samsung TV experts, they seemed to know very little about their TV products or Tizen interface. One of them didn't know what the Smart Hub is!! I have the QE55Q90T used as a business presentation / VC mainly using it to connect to Apple Devices via Airplay. I want to disable Multi-View entirely so I can launch airplay on my device and stream immediately to the television without the extra nonsense. Going into Settings > General > Smart Features and turning off 'Autorun Multi View Casting' did not work. Anyone else have a solution to this?
16-11-2020 04:26 PM
Just put the tv into ambient mode then connect with airplay .. this way multiview does not get in the way .. took me days to figure this outs lol
16-11-2020 05:53 PM
i pressed on the mute button
27-11-2020 09:41 PM
I have the same issue, have you solve it?
thank you
24-03-2021 09:55 AM
Wow this works!
Solution:
30-05-2022 12:49 PM
You are a life saver. This actually works!
18-01-2023 09:12 AM
Doesn’t work on Samsung frame tv unfortunately, turning on or off auto multi view always turns it on when screen sharing. Annoying.
ambient mode does at least solve it .
