advice needed on devices can use
(Topic created on: 30-12-2020 03:04 PM)
mamacita82
I have a new Samsung 7 series smart TV . When I am using you tube or netflix for example, if I need to type in the name of something it takes ages. I am wanting a quicker alternative. Can you buy a wireless keyboard to connect to TV or even a device where you use your voice? Or is there any option though the Samsung smart app where I can type or use my voice from my Samsung phone and it will connect to the TV?
2 REPLIES 2
SirStottalot
Pathfinder
yes you can use a keyboard as long as it is Bluetooth. you should be able to connect it using Samsung Bluetooth pairing and entering a code
Shazzkid
Troubleshooter
Yes, you can buy Samsungs official, and expensive, universal remote, it comes with a voice assistant button, i think its amazon alexa, but it allows you to access menus and search things like movies or tv shows using your voice instead of typing.
