Add second motion sensor to Frame 2021
(Topic created on: 29-12-2021 10:17 PM)
Rob_erto
Hi,
Is it possible to add a second external motion sensor to trigger the frame TV ?
We have ours installed in a long room, the entrance is far to far away for motion to be triggered when you enter. I would like to put a second motion sensor in the room before it which turns the TV on before you get into the main living room.
Is this possible with smart things?
Rob
#75" The Frame QLED 4K
#Motion sensor
2 REPLIES 2
CarlH
Hey @Rob_erto. Yes, this is possible! Pick any Motion Sensor you like (please refer to the SmartThings app to compatible models/brands) and then create a simple automation so If: Motion Triggered > Power: On > Device: Frame TV.
Hope this helps!
Chrischdi
Cool that this is possible! Do I need an addional hub, or is The Frame enough?
