75QN85B\HWQ600b sound issue
(Topic created on: 04-08-2022 08:59 AM)
CulturedReardon
Hi,
Recently purchased a new 75QN85B tv and HW-Q600B soundbar. I have plugged them in via HDMI via the eARC ports on both tv and soundbar, however when QSymphony kicks in i get standard volume sound (music/background noise) however the voices are inaudible. When I try to watch regular TV the sound is distorted and all garbled. CEC+ is turned on, HDMI eARC is set to Auto in tv settings. Worth a note have no sound issues through tv speakers, however if try and select to play through just Soundbar i get no sound at all.
Some things i have tried:
-optical connection (same results)
-updated both soundbar and tv
-different HDMI cord (one i tried with was used on my previous Sony ARC setup with no issue)
-turn off and on again
Anyone with a same setup able to share their settings, or has anyone had a similar issue and able to provide a resolution.
Cheers
3 REPLIES 3
Dazzi
I'm facing same issue with my  QN90B TV + HW-Q600B soundbar. did you find a solution? please share
Members_L2v2vVJ
Same issue with my TV QE65Q. Any idea? Did you fix the issue?
daniel austin
Similar issue with my s95! Sound works fine through tv but nothing through soundbar
