21-07-2021 01:55 PM
My 65" Samsung has finally decided it wont switch on..
Standby light is on, nothing else.
I press the power button and the light goes off, then back to Red.
Removed all cables, reset the one connect box
made sure the one connect cable is seated
tried another one connect box, still nothing at all.
Rang Customer services who loved to tell me the warranty expired Jan 2020.
I now have a very expensive painting on the wall....
Any ideas?
Could it be the one connect cable - no kinks, no movement at all??
