55inch 4k TV
(Topic created on: 03-11-2020 08:35 PM)
Irene84anna
So tonight i turned my tv on to have only half a screen its only just over a year old, its not low down, actually quite high up.. It was fine yesterday. Can anyone help me and give advice about it being fixed.
2 REPLIES 2
Thomasgarrott
Pioneer
power on then off your tv. if that doesn't work then check out your HDMI cable
obitv
Pathfinder
backlights faults on the left-sided. Will need panel replacement if you have some kind of extended warranty or contact any local repair shop if they can do backlight repair for you. Start off my pushing samsung support to arrange free repair or replacement as this seem to be an issue on the N7 series tvs
