19-10-2020 02:29 PM
Hi everyone,
Did somebody noticed a weird noise coming from the speakers at lower volume? Randomly, my TV tends to make a very weak noise similar to bubbling water, regardless the source or input. Not always, but sometimes. I am wondering what can it be or what it might produce the effect. It is not a big issue for me, but I just wonder if anyone has this issue also.
Thanks,
Tuly
03-12-2020 09:19 PM - last edited 03-12-2020 09:25 PM
Hi guys,
I bought my tv a week ago, and now it is making that seashell noise when my sound is on low volume. It is the worst.
Have anyone been in contact with Samsung the last couple of days to hear if there is a solution under way?
03-12-2020 09:45 PM
Hi that stopped working it keeps making those same noises... Is yours a 50" version too ?
04-12-2020 07:44 AM
Oh, I really hoped you had found the gold solution:)
Yes I have a 50” as well.
19-01-2021 10:23 AM
I have a 50" Q60T and the exact same issue. Now I hear it, I cant unhear it. Will try the fix in this thread. Not really acceptable that this is going on months for people. I see there are 2 other threads on here with the same issue. Samsung have replaced Speakers and Motherboards with no improvement, so its a software issue. Some people have managed to get an "uplift" ticket from Samsung which allows them to return the TV.
25-01-2021 03:08 PM
I bought 50" Q60T two days ago and i have same issue. It is annoyying. Someone said technicians solve this problem with changing volume value on their remote controller. And also 60T sound bar has same issue and it has been silver with new update firmware. Have you heard such a thing? Or will it help us?
30-01-2021 04:18 PM
how do you change the hz setting?
23-02-2021 08:32 PM
I have the same problem. It sounds like someone threw the tv in the fish tank!
Lisa
24-02-2021 03:20 PM
Hey Liza and others
Just want to let you all know that I couldn’t get my tv to work. The retailer could not find any problem with it, but I was still able to return it - which I did on the spot.
I now own a Panasonic which have great sound and picture and doesn’t sound like a fish-tank.
kind regards
Christoffer
27-02-2021 10:25 PM
Thank you for your response. On reporting it, they have asked me to do a few options, like turn off the tv at the wall, play with the equalisers/sound. But we shouldn’t have to do this with a new tv. They now want to send a USB to update software, before sending out an engineer, as they think it needs to be repaired. I sent this thread, yet they never acknowledged it!
Otherwise, I’m happy with the tv, yet the underwater sounds ‘on low volume, up to 15’ are bloody annoying!
28-02-2021 12:24 AM - last edited 28-02-2021 12:24 AM
