04-11-2020 11:54 PM - last edited 05-11-2020 01:29 AM
When I turn my speakers on I get the prompt to connect. This is fine (although fully autoconnect would be better) BUT I then have to go into the menu and manually select BT speakers or I have sound from out of sync TV speakers+BT. Defeats the purpose of a connect prompt.
To reiterate, after the BT connect prompt I have to go to the menu and select BT output or I have dual audio from both the TV speakers and the BT speakers.
IF YOU READ THIS SAMSUNG PLEASE FIX THIS!
Also anyone know where I can send direct feedback to samsung or is this it?
MN : UE55RU7470UXXU
PD : 09/01/2020
SN : 0EGZ3HDN100282T
FW : T-MSLDEUC-1371.0
