29-11-2022 01:27 AM
I don’t believe I’ve found a post about this as none were with the Samsung Frame TV’s. When in HDR watching a show or movie I can see the brightness adjusting. Like it dims and becomes brighter scene scene by scene. I’ve made sure all the settings in the TV menu are turned off that would do any automatic adjusting. Even went into the Service menu and tried adjusting the PWMINI 2D and PWMMOVIE settings to a higher setting and it still does it. Does anyone know a solution? Just very noticeable brightness changes while watching HDR. I know the Frame isn’t the most amazing tv and edge lit but this seems like a bug.
22-01-2023 07:33 PM
Hello, I did change the settings as well and with the HDR content problem still occurs. I found a hot fix though. Start the HDR content and then hold the power button on your remote until tv shuts of and starts up again (hold the button the whole time until you see a logo). I suspect the tv resets this way and then HDR is just fine until next power cycle.
Please keep this post updated if someone finds a solution. Thanx
