2 Samsung TV's in the same room
(Topic created on: 12-02-2022 10:18 PM)
Dan_c1
2 Samsung TV's in the same room. Any chance I can control them independently with a remote?
4 REPLIES 4
AndrewL
@Dan_c1: I'm not quite sure what you mean. It won't be possible to control both TVs using the same remote, however if you want to use the designated remote for both devices, then this should be possible. Positioning will be key here, so the more distance between the 2 sets, the better, especially if they're the same model.
WillMichigan
I think I have the same problem. I have two Samsung TVs in the same room so when I press the button on a remote it affects both TVs. So I can't put separate things on each TV. Can anyone help?
Digitaldreams
Great problem !. The IR remotes send out basic codes so cannot differentiate between TV's. All I can think is to try one of the Wi-Fi remote apps available on Google Play Store or Galaxy Store as they initially identify the actual TV you want to control. SmartThings might have a similar function too....
Peter Mok
Seems Samsung don’t want the customers buy multiple Samsung TVs in same room…. They suggest you to buy another brand name
