Go to solution Solved
Samsung Gear Fit 2 Pro Doesn't Work with Samsung Gear App on Galaxy Tab E 8.0
(Topic created on: 25-06-2018 01:27 AM)
sh12345
My Gear Fit 2 Pro does not appear on the Samsung Gear app on my Galaxy Tab E 8.0. I purchased this tablet together with the fitness band since they are both from the same manufacture and the website implies that the fitness band is compatible with android devices. When I open the Samsung Gear app, it says 'Gear not appearing'. Has anyone else had any issues with the app and their Fit 2 pro device?
AndrewL
Hi @sh12345
According to the Samsung website, tablets are not compatible with the Gear Fit 2 Pro I'm afraid. For more information please check the following link: https://www.samsung.com/hk_en/support/mobile-devices/is-my-mobile-device-compatible-with-gear-fit2-p....
2 REPLIES 2
AndrewL
Hi @sh12345
Louis_Erasmus
No the matter is not solved. I have a new tab S6 and am been told the same. This is not acceptable!
