28-10-2023 11:19 PM - last edited 30-10-2023 02:53 PM by Emmi S ) in
I have had this problem for periods and I have reset them several times, even now I have tried but this time it doesn't work. I can use sound balance for as long as possible. Help is appreciated
Varför är min vänstra bud 2 pro mycket lägre volymmässigt än min högra?
Jag har haft det här problemet i perioder och jag har återställt dem flera gånger, även nu har jag testat men den här gången funkar det inte. Jag får använda mig av sound balance sålänge. Hjälp uppskattas
30-10-2023 02:59 PM
30-10-2023 03:12 PM
Hi @Vxd!
What you can try in these cases is to reset your Galaxy Buds 2 Pro. Which you can do via the Galaxy Wearable app > About buds > Reset.
Should problems remain after this, we recommend that you take them in for service. Which you can do via the retailer you bought them from or our nearest service partner: https://www.samsung.com/se/support/service-center/
30-10-2023 03:15 PM - last edited 30-10-2023 03:26 PM
Unfortunately not @Vxd but asked our tech mods to answer, see above 😊
30-10-2023 03:21 PM
30-10-2023 03:28 PM
Hmm I see @Vxd 🤔 I would try what is suggested above, and contact our technical support anyway just to see if there is any more options. Hope it gets sorted out!
