What hub is possible to use with power?
(Topic created on: 11-02-2024 07:28 PM)
Cenimm
Pioneer
I have a usb c hub and it works on my pc with power to charge the device and use the ports on it.
But when i plug it in my s24 it works untill it get power and it flips out and charge for a half second and cuts the power and only the ports works.
Is it a phone issue or is my hub only pc compatible?
3 REPLIES 3
Daniel-M
Helping Hand
Hi @Cenimm!
Do you experience the same problem when using the original charger? If you don't, it sounds like it has something to do with how your USB-C hub distributes power that's causing the problem.
/Daniel
Cenimm
Pioneer
I found the issue.
I used a 25w charger and the phone automatically wanted my phone to use it's own power to have the hub running and when I turn it off it lost the connection and re connected but when I switched to a 45w or higher I was able to switch of that option and now it worked.
User3-14
I have the exact opposite problem.
I just bought the NOVOO RM11 model for My S25Ultra but it does work only when pd input is connected, not even a single usb port work bus powered, while My Samsung Galaxy A56 runs more than 4usb+1sd card with the same RM11 hub
