WiFi connection
(Topic created on: 14-11-2020 05:37 PM)
XGUK
Anyone else having moments where the WiFi just won't work at all?  Using S20 Ultra.
2 REPLIES 2
MartynaK
Beta Moderator
Beta Moderator
@XGUK,
No problem with the WiFi here. The issue can be caused by the Wi-Fi access point so try resetting your router if possible, then go to Settings > Connections > Wi-Fi > Tap the Wi-Fi network in the list > Forget. Now tap the Wi-Fi in the list of available devices > Enter correct details. If that doesn't help, please report the problem via the Members app! :smiling-face:
GooseSnipe
Voyager
yes I'm experiencing this too, sort of, it seems to drop the connection a lot and after a few seconds will use mobile data, then reconnect to WiFi
