Auto switch between WiFi and Mobile Data
(Topic created on: 13-11-2020 09:09 AM)
Flyboy1971
Any one else experiencing issues with switching between WiFi and Mobile Data.  Notifications/messages etc are only updated when back in range of my home WiFi.
Tags (3)
4 REPLIES 4
Hairymushrooms
I'm having all sorts of issues using mobile data, many times it wont work and i have to put aeroplane mode on and off to get it working.
doesn't last long tho before it's off again.
same as you for messages and notifications, only working on WiFi.
Kondek85
Pathfinder
I've noticed the same when streaming music, at some point it tells me to check internet connection and there is no way to bring it back. It happens on different parts of the town co I don't blaim my provider for this. Happens on 5G and also on 4G.
Ahassona
Pioneer
Just had the latest update this morning and it seems to have sorted out the 5G issue!
MartynaK
Beta Moderator
Beta Moderator
@Flyboy1971,
If the issue persists, please report the problem via the Members application! 😉:hand-with-index-and-middle-fingers-crossed:
