Where is wifi calling setting
(Topic created on: 05-11-2022 12:15 AM)
Capman
I cant find wifi calling setting anywhere i want to turn off does anyone one know where to turn it off please s21 ultra android 13 beta thanks
4 REPLIES 4
Ads
Pioneer
Go into the Phone app, tap on the 3 dots for the settings menu and WiFi Calling is towards the bottom of the page
Capman
Its missing on mine theres not one setting to do with wifi calling on my phone
ScottyUK
Pathfinder
It probably means that your cell network provider doesn't support it. You need a capable phone AND a capable network
MagdalenaPo
Beta Moderator
Beta Moderator
Hello @Capman
If you can't see the Wi-Fi calling options in Phone app settings, you should contact your network provider to check if Wi-Fi Calling is available on your network and activated for your device. 🙂
