Vertical Drawer - Sidebar
(Topic created on: 06-12-2024 02:43 AM)
AJAY92
Hi all,
Loving the beta so far.
Is it possible to hide the sidebar (letter search) on the right of the vertical app drawer? Highly annoying.
4 REPLIES 4
Tazim
Helping Hand
It automatically disappears when you stop scrolling though
AJAY92
Yes, but appears when I'm scrolling and sets off my OCD.
AnnaMaz
Beta Moderator
Beta Moderator
Hello @AJAY92,
Thanks for sharing your feedback 😊 If anybody else would like to see this functionality - please let us know in the comments, it would improve the chance for the suggestion to be implemented.
Have a good day!
Side navigation
Hello dear community.
Did you notice that after the last update, selecting an image from the sidebar was removed, it was replaced with a kind of smart selection, but now it is very inconvenient, and if in the past the selection would automatically select exactly the image on the screen, now you have to do 3-4 actions each time before you can select the desired screenshot. And I didn't find the way to roll back  the old type, please help!
