Network switch issue - S22ultra
(Topic created on: 01-09-2022 06:20 AM)
KSharma
Pioneer
I am facing network switch problem from WiFi to mobile data , it doesn't get switched automatically. I need to restart my mobile to get the mobile data if WiFi not available. Are you guys also facing the same issue?
3 REPLIES 3
AnnaMaz
Beta Moderator
Beta Moderator
Hello @KSharma,
Yeah that definitely shouldn't happen 😓 Have you tried wiping cache partition?
You can do it through the Recovery mode > Turn off your device > Connect your device to the PC via USB (not to the charger) > Wait until the message that the device is being charged appears > Press and hold down the volume up and then power buttons and hold them until the device turns on > Recovery menu should appear > from there select "Wipe cache partition" (you can navigate using volume up/down buttons and confirm with a power button).
If that doesn't help, could you please report this issue via Samsung Members app so that the developers can take a look? 😉
Have a good day!
Sarahabb
I have exactly the same issue.... Its so frustrating. Forever putting my phone in airplane mode to get it to connect to network after leaving WiFi. Did the solution help?
Sarahabb
I also have S22 Ultra
