Battery life
(Topic created on: 23-01-2025 06:05 PM)
Mombasaboy
My battery runs out quick on the new Beta software! Can anyone suggest why ?
4 REPLIES 4
weskerevil
Helping Hand
Have you cleared the cache and run the galaxy app booster app
JDVY
Could be a bug could be something running in background with high usage hopefully you can find the issue!
Galacticdude
Pathfinder
Same for me
I dont know if im being paranoid but it seemed to start on 22nd
Coincidentally the launch of the s25
AnnaMaz
Beta Moderator
Beta Moderator
Hello @Mombasaboy,
Thanks for reporting! Please also send an error report through Samsung Members app so that the developers can take a look at what may be the cause
Have a good day!
Have a good day! ☀️
