Battery Drain
(Topic created on: 05-09-2023 03:42 PM)
84RRY
Is it me or is there battery drain with beta 1
8 REPLIES 8
theoracle
Pathfinder
I have not seen any drain myself, battery life still very good for me.
Clive7409
Voyager
I keep thinking battery life worse, but not drastically maybe an hour or 2 less... but nothing to prove that the case yet.
DC_UK
Mines definetely worse, charging now twice a day instead once. Wanted to. Downgrade but unfortunately it would mean a total reset so I'll have to live with it
Jamsterdm
Helping Hand
Seems okay, if not a tad bit better for me tbh
acide
Definitely faster battery drain
MartynaK
Beta Moderator
Beta Moderator
@84RRY,
I haven't noticed a significant battery drain since the Beta update 🤔.
Please, report the issue via the Samsung Members app attaching log files, so that our developers can have a look into the problem.
Sirfoxelot
Voyager
Nothing for me.
Battery seems slightly better than Android 13/One UI 5.1
84RRY
I was wrong, mine runs for about 24 hours give or take.
