Battery drain
(Topic created on: 29-01-2025 10:12 AM)
Mombasaboy
Hi everyone
Not sure if anyone else is experiencing this battery drain since I've been on the UI 7. I'm on battery saver mode a few apps running in the background but nothing major same as I had before but it didn't drain so quickly.
Any advice,help will be much appreciated.
5 REPLIES 5
xNightWulf
Pathfinder
Google how to clear the System Cache, it worked for me
Mombasaboy
I'll give it a go , thanks for the advice
AnnaMaz
Beta Moderator
Beta Moderator
Hello @Mombasaboy,
Thanks for reporting! Please also send an error report through Samsung Members app so that the developers can take a look at what may be the cause
Have a good day!
Mombasaboy
I have , the battery still drains quickly whilst using the phone kindly find a fix asap. Thank you
Gav4b
Voyager
hi since getting my s25 ultra I noticed that the battery was running down quicker then what my s24 ultra did but I found a fix that helped me I noticed that they have ram plus on and set to 8gb I have turned mines off it restarted my phone and it doesn't seem to be running down as quick I'm not sure why ram plus would but this has helped me plus I don't see any difference when having this off should give it away and see if it helps you 1738664483509.jpg
