29-09-2021 11:22 AM in
Other SmartphonesAndroid 11 One UI 3.0
Hello,
Does anybody know if there is any way to customize the Led notification for this phone?
Now It just slowly blinks for some apps which is not very useful since you have to stare at the phone to see if there is anything blinking or not.
Is there any solution to change the color, blinking/ always on per application maybe?
Thank you
04-10-2021 09:50 AM in
Other SmartphonesHi!
I am also using an Xcover Pro.
Prior to the Android 11 Update I was using an App called Lightflow. You can customize the blink rate and color of the LED for the notification of all installed apps individually.
HOWEVER: After the Android 11 update the app still works, but now it is vibrating one time when switching the screen off and every time you receive a notification. Haven't found a way to turn that off. Came after the Android 11 upgrade and seems to have something to do with the how notifications are done.
Gave up on it, another thing an update broke on a perfect running phone before the update.
