S8 smart lock - trusted location issue
(Topic created on: 02/05/17 16:00)
sabina_bl
Other Smartphones
Hi,
the smart lock - trusted location option is not working as it should do.
i've set up my home address as a trusted location, however, my S8 device is unlocked everywhere.
just realised this while i was in the office, that i can access my device withouth using the PIN or the fingerprint.
i've oppend the maps and the location that it shows up is correct. 2miles away from my home address.
the only workaround that i found was to turn off the trusted location, and now the device is asking for the PIN.
this is a serious security issue. the trusted location option is not that trusted :smiling-face:
any idea?
thanks,
sabina
116 REPLIES 116
PariahComplex
Other Smartphones
No luck, had to unlock every time I used at home after going through those steps, gave up just doing the device proximity to keep it unlocked now, still sucks because it messes up the stuff I have set for geofencing
Tewe02
New Member
Other Smartphones
Trusted location I not working even after trying common fixes. Sending texts requires 3 bars of cellular service. Waiting for the Pexil 3
JohnnyJames
Other Smartphones
SOLUTION
None of these solutions worked for me BUT what did is setting my home address in the Samsung galaxy account.
It has been 2 days and smartlock still works.
I Hope it works for you too.
Google settings has nothing to so with smart lock.
Find "Galaxy Apps" amongst the rest of your apps. If you cant see it, search for it I am looking now for where to add your home adress but cant find where i went.
Ill come back with proper instructions when i find it again.
Just know that the solution is to add your home to actual samsung account. Ill be back when i remember how i did it. Im pretty sure it was in "galaxy apps" good luck and if someone else finds it, please post for others as this was a very annoyong issue
PariahComplex
Other Smartphones
Nothing has worked for me yet either, gonna try what you said, in galaxy apps click my apps, then email at the top then add address to Samsung account?
Nuija
Other Smartphones
Hi Johnny, when you added your address to yout galaxy account service, that service gives that location to Google Map services. Trusted places means trusted places, not just home.
I had my home address also registered but it did not help at all, because where I live the Google Map service sometimes locates me outside my house  when I am inside my home.
I actually had to add two most common locations where Google Maps finds me most often when I am at home and now the system works most of the time. ; )
JohnnyJames
Other Smartphones
Sorry. I cant find where i did it but there was a google maps thing like when you add it normally but it was in my samsung acc somewhere. It was only 2 days ago. If you figure it out let me know as its. Bothering me now that i cant remember
Nuija
Other Smartphones
Both Samsung and Google are really good at hiding those settings, every system update tries to bury that setting to even deeper and under a newly named category.
It is usually in "Settings" (cogwheel icon) and under some subcategory of category "Lock Screen and Security", in subcategory which name can also slighty change depending system version and Samsung's latest idea of usability 😃
JohnnyJames
Other Smartphones
Ok got it.
Go into settings then
Cloud/apps
Select your samsung acc
(It will say your email underneath
Then click places and add your home.
Worked for me and is the only thing that did.
GOOD LUCK let me know how it goes
Nuija
Other Smartphones
Still doesn't work with me, since phone sees me in different location where I actually am.
Can you check closely time to time where your phone is located in  Google Maps. If the location dot stays in the same place all the time then it works, otherwise not.
Whether the address is called home or work is irrelevant.
Today my phone thinks persistently that I am not in those two locations what I have marked around my home to be recognised as my home, and the lock is not working again.
The saddest thing here is that there is no option to define the actual range around that located position that would always be considered safe. That would solve all these issues...
JohnnyJames
Other Smartphones
Have you tried holding the location button and ticking those box's for max accuracy?
