Support
Open search
S7 edge bluetooth call problem
Highlighted
When using blyetooth to make a call there is a lag and then a message box which says the action "isnt responding, do you want to wait or close" when to press close, the call is cancelled and remakes the call successfully.
4 REPLIES 4
Highlighted
Hey there, Dj_tricky! :smileyhappy:
What device have you got your S7 edge paired with? Have you tried unpairing and then re-pairing them; or restarting your phone? Also, is everything up to date on your phone - both the software and all of the apps?
 Say "Hello!" to the Community in The Introduce Yourself Thread.
Highlighted
Hi
My Bluetooth is a Samsung HM3300, I have re paired several times, has been like this since I upgrade from S6 edge, all up to date
Highlighted
Thanks. Try clearing the Bluetooth Share app's cache and data and let us know what effect that has: Apps > Settings > Applications > Application manager > More > Show System Apps > Bluetooth Share > Storage, and Clear Cache and Clear Data.
Highlighted
Hello
I clear the data and cache. It worked for the first call but them failed on the second call. If you call the 'mail' it fails, if you call the '*31#' it works.
I have attached screenshots
Top Liked Authors
