17-04-2020 03:14 PM
Hi all,
So I've woken up this morning with an issue on my S7, The phone appears dead, but there is a solid red light on? I've tried all the holding button tricks but nothing is working.
This only seems to have happened after I put it on charge, Is it down to a Battery issue or something else? I'm planning to send it in for repairs, but unfortunately my phone has a lock screen enabled to which I can't remove and I've not actually backed-up my files for a few months. Eugh!
Is there a way of sending it in but not having it wiped of all information held on the phone? I'm quite anxious that I'll lose all access to my apps, files, photos among other things due to the two-step verification too.
Thanks for any suggestions/help etc.
Regards, Lyndsey.
P.S. I might sound calm in the post but I'm quite literally stressing out on the inside. Argghh..
17-04-2020 04:17 PM
Hey @FindAndSeek ,
no worries, I would happily take a look into this with you. Is the red light steady or it's blinking? Do you have the charger that came with the phone? If so, can you connect this to the phone and leave it in for at least 15 minutes? After that try to turn the phone on.
17-04-2020 05:07 PM
17-04-2020 05:14 PM
I'm glad to hear that our colleagues have provided you with the next steps to get this repaired @FindAndSeek
Due to security reasons (GDPR legislation) all the phones sent for repair will be restored to factory settings, which means that all the data will be erased.
06-05-2020 01:58 PM
I am also having this issue. It just happened a couple of days ago. I need access to my phone info today. Please help!
06-05-2020 02:00 PM
