Showing results forΒ
Search instead forΒ
Did you mean:Β
Help for battery life πŸ”‹πŸ”‹πŸ”‹πŸ”‹
(Topic created on: 18-02-2022 08:54 PM)
Harrison-Vaughan
Other Smartphones
Put a black screen  on your background this will turn off some pixels and help your battery hope this helped
3 REPLIES 3
BandOfBrothers
Samsung Maker β˜…β˜…
Other Smartphones
Thank you for sharing this tip @Harrison-Vaughan  πŸ‘
If a person conducts a forum search they'll also come across existing threads also holding good battery saving tips.
I for example use Dark Mode.
Daily Driver > Samsung Galaxy sΒ²Β² Ultra 256Gb in Phantom Black.
I'm here to help.
Harrison-Vaughan
Other Smartphones
Thanks for looking at all my posts
rondaclary
Other Smartphones
Thank you so much, that did the trick!
