Go to solution Solved
bluetooth headphones volume problem after S7 oreo update
(Topic created on: 19-06-2018 01:22 PM)
nurri99
Other Smartphones
After updating my S7 to oreo, I can't lower the volume of my bluetooth headphones (JBL E45BT) (even the lowest volume possible is still way too loud). Before the update everything was just working fine. Does anyone have an idea on how to fix this?
Go to solution
21 REPLIES 21
sofyansutrisna
Other Smartphones
yes it is now missing 😞
Strange200
Other Smartphones
Go to Connections -->Bluetooth-->press the three dots on th top right-->Advanced-->turn off ringtone sync
Then reconnect headphones
The sound will be normal
Hope this helps you
