Go to solution Solved
bluetooth headphones volume problem after S7 oreo update
(Topic created on: 19-06-2018 01:22 PM)
nurri99
Other Smartphones
After updating my S7 to oreo, I can't lower the volume of my bluetooth headphones (JBL E45BT) (even the lowest volume possible is still way too loud). Before the update everything was just working fine. Does anyone have an idea on how to fix this?
Go to solution
21 REPLIES 21
Aryn
Other Smartphones
Wow, this worked great!  I have been having such problems since the update, and this worked like a charm.  I was so disappointed that I couldn't use my headphones anymore.  I was told to unpair everything I own and re-pair, and that didn't work.  It seemed like nothing would work, but this did!  Thank you so much!
Jeremy97
Other Smartphones
You can sort the problem out properly by going to:
Settings > Connections > Bluetooth > [three dots in top right corner] > Media volume sync > Off
Hope this helps.
DrFausto
Other Smartphones
Thank you! This worked nicely for me!
MichaelW70
Other Smartphones
This worked and solved the issue.
ERIKDRONE_
Other Smartphones
That option helped me! Now finally i can listen to music in my hbq-q32 buds!
Kani
Other Smartphones
The BT Sync off did it for me too. The Marshall Kilburn suffers from this.
Thanks!
Catedd2
Other Smartphones
Thankyou So much. EASY when you know how. 🙂
Snijkoek
Other Smartphones
Thanks, Hostet. This worked for me on my new A40. All other answers were not working.
Also great to know how to enter developer mode.
Adonyx
Other Smartphones
As of today, the "media volume sync" option is missing from settings. I can no longer lower the volume on my headphones to a reasonable level.
NoahW
Other Smartphones
Thank you so so so much. You saved me from throwing my earbuds out. Once again thank you I greatly appreciate it.
