S20 ultra camera focus problem
(Topic created on: 28-09-2022 03:32 PM)
waddy1963
Hi help needed my camera will not focus unless its on 4.0 or more & even then it's hit & miss
39 REPLIES 39
TerminatorOWNZ
Indeed, the situation is beyond desperate (((((
That's a shame I haven't noticed it in the first place to be able to match it with the exact update number that has impacted on camera focus.
My current failed focus primary camera module photos rate is about 2 failed out of 5 😞
I can't believe that so few S20U users were impacted, so this problem is still not widely spread enough.
Adding a few more photos:Quick snap with no focusQuick snap with no focusAnd the next one after realized there was no focusAnd the next one after realized there was no focus
F1rust
Navigator
If you read other posts on different thread some people haven't noticed how bad their photography is until they compare with other people's cameras. I think Samsung need to get a grip before they lose customers. I can understand losing focus on x100 but not on the default setting! I use .5 now to take photos to ensure some sort of focus. A bad situation
TerminatorOWNZ
Totally agree! x0.5 and x4 camera modules are totally fine (so far! 😅😶)
And it took me time to realize there was a fault in the primary camera module focus process. When it's in not_focusing mode, it means the focus does not go further than 1-2m away! Everything that's near the focus easily snaps on. But if you want to capture some scenery, you notice that immediately by looking at such a resulting picture. And that's usually long after that moment is gone 😫
F1rust
Navigator
It is such an obvious fault for us to see. I noticed it thinking my lens was dirty or condensation on it but it wasn't dirty at all. I tried every "fix" I could not get it to work. If I took it to Samsung they factory reset everything and even then it may not work and costs me time and effort on a new phone!
TerminatorOWNZ
Indeed 😭. The factory reset on a daily-driver phone (without any guarantee that it would fix) is equal to buying a new one. I can't even think of it as a possible solution option. So at this point, there's a reasonable question why Samsung... What if the S22 ultra would have the same "support"?
I really am looking at another Apple ecosystem, as my wife has been happily using it for over six years. Even the oldest iPhone 7 from 09.2016 is still receiving updates and is being supported!
F1rust
Navigator
Yes it wouldn't be too bad if they could guarantee a success. At least then it would be worth all the effort. I don't like being tied to apple . They are excellent but so expensive. Samsung isn't cheap and is a good system but let down by this software issue that they produced
TerminatorOWNZ
Well, here in Ukraine, the prices are equal for both Samsung and iPhone flagman phones (S22U & 14 pro max). It's a matter of preference - Android or IOS. I like both almost equally but am just used to Android. Been through Galaxy S1, Captivate,  Infuse, S3, S4, S10L, and S20U, not to mention lots of other Samsung devices... And I've selected the S20U specifically and intentionally for the best camera modules at the time. And having a major deal-breaker feature not working  properly is, by all means, unacceptable and frustrating 😠
I do really hope for current issue visibility so that the support/dev team would escalate it and release a patch in the upcoming update.
komis
Same problem after software update. Primary camera doesn't focus. Isn't a hardware issue. Changing from photo to video (or portrait) and backwards fixes the focus for this session.  Also no fix works, like  clear cache, safe mode etc. It's just a software bug that Samsung should have already fixed.
TerminatorOWNZ
Sorry to hear that 😞
Just for your information. I've updated recently with another update from the 1st of October 2022; alas, nothing has changed related to the S20 Ultra camera focusing issue 😢
TerminatorOWNZ
Keeping this topic alive.
Still experiencing the focus issue.
I almost used to "tap" my premium Samsung Galaxy S20 Ultra flagman phone everytime before taking a picture.
That's beyond frustrating 😭😡
