Cable android auto connection problem on s24 ultra
(Topic created on: 27-03-2024 09:39 PM)
Ahmad hijazi
After 10- 20 minutes of connection it does this suddenly I've tried changing several cables and cleared the app cache and data and preformed a software update and a factory reset nothing worked can someone help me 20240323_001206.jpg
6 REPLIES 6
DarrenMC
I have this issue with AA and charging. The phone will intermittently stop and start charging
Ahmad hijazi
Did you find any solution for this problem?
DarrenMC
I recently cleared the cache, which temporarily resolved the issue. However, the problem reoccurred approximately five minutes later. I received a system update a few days ago, which I initially believed had rectified the problem, but unfortunately, it has since resurfaced. The issue appears to be intermittent, with periods of functionality followed by unexpected disruptions.
Ahmad hijazi
I'm having exactly the same problem, i gave up on cable connecting I tried everything that could be done nothing worked and no one could help
DarrenMC
Hey, I was checking out some forums and it looks like a lot of people are having this same issue. It seems like it might be a software problem. Some people have even gotten new phones, but the problem still happens. Does your phone work sometimes?
Ahmad hijazi
It work for 10-20 minutes then it disconnect immediately
