Washing machine sound
(Topic created on: 09-05-2021 12:20 PM)
AndyDK
Simple question,
I’ve bought a Samsung washing machine WW5300 WW95T534CAE, and a dryer DV95T5240AE, but how do I turn off the sound and music playing when it’s done?! It’s terrible it need to play a long loud melody!
4 REPLIES 4
AndrewL
@AndyDK: For the WW5300, press and hold the Additional Functions button for 3 seconds (pointing hand with a '+' symbol) > Turn the navigational dial and select Alarm > Press 'O' (OK) > Tap 'O' again to turn the alarm off. Sadly the dryer doesn't appear to be a UK model, however I recommend checking the user manual, do a key word search for 'Sound' and the relevant steps should be visible here.
https://www.samsung.com/no/support/model/DV95T5240AE/S4/
AndyDK
Thanks for fast reply! It’s only the tone when it’s finish, right? I can’t turn off all the sounds like when spinning the wheel to choose a program?
I have a similar menu and settings for the dryer so maybe it’s the same method.
AndrewL
@AndyDK: The AddWash alarm, the cycle completion melody and the power-off beep will be muted, but not all operational sounds. I hope this helps.
AndyDK
Ah okay, what about the startup sound when I powered it on? It is very annoying to hear first song of a classical song just to wash clothes 😅
