Samsung Front Load Wont Finish Spin Cycle
(Topic created on: 16-07-2021 03:16 AM)
nasarath
Hi, my washing machine usually gets stuck at 6 minutes and will keep slowly turning the clothes, pick up speed, and then slow down again for hours. Eventually I give up and just chuck the clothes into the dryer, but I want a fix for the washer. I have read another persons post about the load being uneven, but I do not think that is the problem because I have manually moved the clothes around and it still will not finish the cycle. It does this every cycle. Does anyone else have this problem?
12 REPLIES 12
Harith80
hi, problem settle? I face the same issue, if it done please share with me the solution..
nasarath
Hi! I’ve found that if I do smaller loads, it does better.
dengor
The engineer found the problem was a broken motor mount causing the issues. He replaced the mount and fixed the issues for me.
