30-01-2021 08:21 PM in
Home AppliancesI recently bought a Samsung Heat Pump dryer but can’t find the hot air function. Actually clothes are not drying.
Appreciate your support!
31-01-2021 01:56 AM in
Home Appliances
hello
check warm air on panel, check steps below from manual
Doesn’t heat.
• Check the home’s circuit breaker and fuses.
• Select a heat setting other than COOL AIR.
• Check the case filter and Heat Exchanger Filter and clean
them if necessary.
• Dryer may have moved into the cool-down phase of the
cycle.
thanks😉
