15-03-2020 05:32 PM in
Home AppliancesI have a dishwasher WW90M643OBW and I need a dryer. As I understand it, I need to fasten it, but how can I know what is compatible?
The dryer I'm looking at is FTCM118XBEU
One more thing, does this dryer require an exhaust duct? There doesn't seem to be an output for that, but I assume it needs one or it just vents into the room?
15-03-2020 05:44 PM in
Home AppliancesHey @famadorian. That doesn't appear to be a model number I'm familiar with. Can you tell me where it is you're based?
15-03-2020 08:27 PM in
Home Appliances15-03-2020 08:39 PM in
Home AppliancesThanks. It might be worth contacting Samsung in your region for more info on this (I'm in the UK). This link will direct you to their page.
16-03-2020 11:09 AM in
Home Appliancesok, but generally, is there some sort of mounting kit or don't I need one? I see there is some sort of screw connection on the back of my washer.
16-03-2020 11:17 AM in
Home AppliancesWe do have Stacking Kits for certain models. Here is how they work.
16-03-2020 12:28 PM in
Home AppliancesOk, found a solution.
First of, I gave wrong model number for the dryer, which is DV70M5020KW.
Also, here's the correct stacking kit:
https://www.samsung.com/no/ha-accessories/sk-dh/
Thanks;)
16-03-2020 12:47 PM in
Home Appliances21-07-2020 10:40 PM in
Home AppliancesHello,
Please, can you help us with the correct stacking kit for WD80J6? The specification for SKK-DD says that it fits WD80J5, but is there a difference between WD80J6 and J5?
Best regards,
Krum
